IradvC5235 - HDD
  • MunsterTech
    • Sep 2014
    • 381
    [Dead] IradvC5235 - HDD
    Hi,
    Tomorrow I am going to a IRadvC5235, has had a couple of E602 on and off, I saw on SIMS about the mod for noise from the fan affecting the HDD. The HDD check fails around 53 percent, just stops, machine is up currently but has Uniflow installed.
    Am I right in thinking that Uniflow is installed onto the HDD and not on the main controller? Putting a new HDD into the machine will need uniflow re installing on the HDD? If so, is that a big job? Anything I need to be looking out for etc, never installed uniflow before, so any tips will come in handy.
    tks
  • Eddie
    • Jun 2009
    • 31
    Re: IradvC5235 - HDD
    Replace the hdd
    uniflow is a meap app...you should not need to reinstall. It never hurts to do a backup via the web ui
    • MunsterTech
      • Sep 2014
      • 381
      just a update, when the HDD was replaced the Meap apps go with it, so must be stored on the HDD, so had to re install uniflow
