Owner acr copier repair, inc
  • JIMA1020
    • Sep 2012
    • 12
    HOW TO RESET FUSER CODE E001-00 ON CANON MF4890dn new machine out of box
    (alexander1020@charter.net
  • copier tech
    • 8131
    Re: Owner acr copier repair, inc
    New out of the box? Send it back for a refund!
    Even if you reset the code it could keep returning.
    • teckat
      • 16083
      --------------as stated by copier tech-------return item
      there is no error clear in service mode
      info below is just noted----
      To reset the power supply after protective function activation, leave it unplugged for 2 minutes
      ●●Safety function
      The host machine equips the function of stopping 24V of fixing assembly and the high voltage
      power unit to avoid users and engineers from getting burned or electric shock.
      When the cartridge door is opened, the interlock switch (SW501) is turned off and 24V
      supplied to fixing assembly and the high voltage power unit is shut.
      Engine controller CPU determines the door open when each interlock switch is turned OFF.
      minutes before plugging it in and turning it on.
      E001-0000 Abnormally high temperature (detected by main thermistor)
      The main thermistor detected an abnormally high temperature 235 deg C) during temperature control
      When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
      (1) Check that the heater resistance measured between 1PIN and 2PIN of the cable (J101) on the Main Controller Board is in the following range.
      Replace the Fixing Assembly when the resistance value is abnormal.
      (2) Check the connection of connector (J101) on the Engine Controller Board.
      (3) Check the connection of connector (J552) on Engine Controller Board.
      (4) Replace the Fixing Assembly.
      (5) Replace the Engine Controller Board.
      • JIMA1020
        • Sep 2012
        • 12
        Originally posted by jima1020
        how to reset fuser code e001-00 on canon mf4890dn new machine out of box
        thanks to teckat. Will return canon mf4890
