iRA C5235i scan to email problem
  • Rich
    • Mar 2011
    • 30
    Hi everyone,
    When scanning to email in any file format the attachments either cannot be opened of a message is displayed "file is corrupt or damaged". It doesn't seem to make any difference which version of windows is in use (Windows 7 & Pro 8.1 have been used).
    Scan to USB & scan to file works perfectly when set used for diagnostics but are not options allowed on the customers network. The issue seems to be with the process of attaching the scan to the email as when using USB/file the scanned image is sent to the destination on its own rather than as an attachment.
    Canon have been out, main controller 1 & 2 have been replaced as have the Image Operation Sub PCB and Reader Controller on their advice.
    HDD has been replaced, firmware versions 41.01 & 43.01 have been tried by Canon with no change.
    We have put another device on the same network port using the same cable and all works fine. All settings have been compared between the 2 devices and are identical.
    There are no errors being logged at all.
    All other device functions- copy, print etc. work perfectly.
    Can anyone offer any suggestions other than a gallon of paraffin & a match?
    Any help appreciated.
  • JPiek
    • Oct 2014
    • 435
    Re: iRA C5235i scan to email problem
    I doubt if i can really help, but will do some brainstorming
    *All filetypes get damaged ? Pdf, jpeg ?
    * Works when scanned to file
    * Works with another Canon
    - have you tried swapping the networkcard ?
    - Do filesize differ between both Canons and/or between maild doc. and scanned to file doc. ?
    Johan
    • guitar9199
      • Sep 2016
      • 1100
      Worse comes to worse, you could always "Initialize All Data Settings", and start with a clean slate. Make sure to do a P-Print and export your address book before you do it though, and check all your settings.
      Good luck.
      • Rich
        • Mar 2011
        • 30
        Hi. Thanks for getting back to me.
        Yes- all file types are damaged/ corrupt.
        Another Canon works fine.
        Setting up a file on my laptop and connecting directly to the device works so does scanning to a USB stick.
        Network card has been changed as it is part of main controller 1.
        File sizes are identical between both Canons and also scan to file / USB.
        Customers permissions do not allow a scan folder to be set up on users PC so can't test to file/folder over the network and their IT refuse to set one up for diagnostics due to security implications.
        • Rich
          • Mar 2011
          • 30
          Good luck.
          Thanks for your help. It really is the last resort with this site and something I have considered. I'm thinking it might have to come to that though.
          Cheers
          • JPiek
            • Oct 2014
            • 435
            Init all data doesn't reset the printer. Just user/customer settings/data.
            But in short: if you don't use the customers network, it works ? Can you use another smtp server for testing ?
            Johan
            • copier tech
              • 8174
              What SMTP account are you using?
              Have you tried using another SMTP account, for example set up a gmail account, (smtp.gmail.com) port 465 etc program all the relevant settings & try that.
              • Rakesh
                • May 2012
                • 72
                try changing smtp server & port no...as suggested by copier tech
                View Life As A Continuous Learning Experience...
                • Rich
                  • Mar 2011
                  • 30
                  Hi everyone.
                  Thanks for your help on this one. I've resolved the issue by changing the IPMTU setting in service mode (copier > option> network> IPMTU). The default is 10 which means that the size of the packets for sending data over the network is 15000 bytes. I've changed this to 8, reducing the packet size to 13000 bytes and all file formats work perfectly every time.
                  Cheers.
                  • copier tech
                    • 8174
                    Thanks, i've never heard of anyone using that setting before!
                    • Rich
                      • Mar 2011
                      • 30
                      I think that makes about 20,000 of us!
                      Apparently the customers IT had seen the issue before but didn't think it was worth sharing the knowledge. Don't you just Love 'em?
                      • JPiek
                        • Oct 2014
                        • 435
                        Offcopurse not ! They probably created the problem themself by changeingt the MTU on some switch...
                        hi all can some pls tell me the difference between interface mtu and ip mtu. the confusion i feel is when we set the physical mtu it going to affect the ip packets anyway right then why do we have the ip mtu option. can someone pls explain the difference between them . sebastan
                        Any chance you can figure out what the setting was on the other Canon you tried and wich worked ?
                        Johan
                        • Rich
                          • Mar 2011
                          • 30
                          Not without visiting the site again and to be honest the security is so tight they won't let me in just to check it.
                          • JPiek
                            • Oct 2014
                            • 435
                            To bad...
                            Johan
                            • Rakesh
                              • May 2012
                              • 72
                              Hi everyone.
                              Cheers.
                              good find, thanks for sharing.
