IRADVC5051 One Path DADF double feeds
  • RHodg57
    • Dec 2013
    • 191
    Has anyone experienced this problem? Canon IRADVC5051 DADF-W1 one path double feeds originals.
    I replaced the separation roller with the new part number FB5-6586 and it seemed to help but problem
    has returned. I am going to change the torque limiter when I go there because it is mentioned on another
    forum post. Is there anything else anyone has ran into on this problem?
    We have quite a few of these machines out and have never had a complaint of any double feeding.
  • tinnyjay
    • Oct 2009
    • 663
    Re: IRADVC5051 One Path DADF double feeds
    Change pick up roller also.
    "Who loves the roses,must also bear thumbs"
    • teckat
      • 16083
      "STATIC"
      When I keep feeding documents , they build up charges on paper, especially crappy stock and more if paper is that recylced garbage.
      Had customers that keept documents stored on a rug\ or floor near heat vents\ or AC vents.
      No need to guess how many service calls this generated.
      Just to prove my point to them, I opened a fresh ream of paper, stacked in DF 30 sheets, ran over and over a few times with no double feeding.
      • copier tech
        • 8187
        There is a modified separation roller for the irac 5051 single pass DF FB2-7777-020
        • JPiek
          • Oct 2014
          • 435
          Check if the ADF Lid closes correct, I had a MF9220 where the tab 'just fell off' according the customer. The lid didn't put enough pressure on the rollers, so it would try to eat the whole stack of paper in the ADF at once...
          Johan
          • Canuck
            Tech Specialist
            • 1713
            Put the 7777 sep roller back in and install the improved torque limiter. This bulletin shows some other issues too
            • RHodg57
              • Dec 2013
              • 191
              The machine has the DADF-W1 and Color Image Reader M1. Those don't show up on that tech pub.
              Not sure if the update parts listed are for this document feed. Hadn't heard any complaints for 6 months
              but now it's doing it again. For now I am going to change the torque limiter and rollers. Are there any
              pubs for this DADF?
              • teckat
                • 16083
                pubs for this DADF?
                nothing new
                October 27, 2011
                Multi-feeding Originals on DADF-W1
                Problem :
                Originals were doublefeeding/multifeeding into the DADF-W1.
                Tech replaced separation and feed rollers, and adjusted separation pressure,
                with no improvement in symptoms. Originals were within machine specifications.
                Solution :
                A defective torque limiter, FC7-2494-000 was the problem.
                **As of the date of this article, FC7-2494-000 is a valid part number.
                In the imageRUNNER ADVANCE C5051/5045/5035/5030 Revision 1 Parts Catalog, November 11, 2010, a new number was
                introduced for the torque limiter.
                It is FC8-5907-000.
                As of the date of this article, both part numbers are valid and parts are available.
                • RHodg57
                  • Dec 2013
                  • 191
                  I replaced the torque limiter with the part number FC7-2494. The roller I used was the FB5-6586. I didn't adjust the
                  spring pressure. I ordered the other torque limiter FC8-5907 that was mentioned and the FB2-7777-020 just to be
                  safe. I did run over 250 printed pages through the DF and didn't get any double feeds. Kind of a damned if you do, damned if
                  don't at this point. Thanks for all the replies.
                  I did change the feed and pickup rollers that were mentioned also.
                  That FB5-6586 roller came out when the IR5050 machines were made as
                  a replacement for the FB2-7777. Maybe there is a reason they didn't use
                  those on these DF's. Not sure.
