iRADV4035
  • Blues Guy
    • Aug 2009
    • 216
    iRADV4035
    Good day everyone,
    I have 2 units iRADV4035 with same problem. You can power "ON" the machine no error code appear and ready to copy like normal. But when you press the copy button or any numbering at the key pad and as well the display the machine no response at all. Looks like the panel display are jam and machine freeze no function.
    We have swap the whole panel assembly, check all the socket in correct position and DC con pcb but still the same. Any idea where go wrong ?
    • 8172
    Re: iRADV4035
    Can you open the RUI & print as normal?
    • Blues Guy
      • Aug 2009
      • 216
      Re: iRADV4035
      I miss out this try this method. Any way I can't set the IP address if I want to try print cause the panel display no function at all when I press all the button (panel freeze)
