How to register any envelope size
  • Vegas10128
    • Jan 2017
    • 9
    Hello copytech,
    Recently came across an issue with having to print wedding envelopes.
    The size is not on the canon copier.
    Model i have is Canon IR C5180
    Im sorry if this is a super silly question or thread to start but any help would be best appreciated!
    • 16083
    Re: How to register any envelope size
    Originally posted by Vegas10128
    Hello copytech,
    Run in Bypass Tray-----------------SELECT ON CONTROL PANEL --change the X/Y coordinates on the control panel:1) Choose Stackbypass on the control panel
    2) Choose envelope (Press OK key)
    3) Choose Irreg. Size
    4) Put in x/y coordinants:
    or in Print Driver Settings
    • Printing on envelopes, do not allow more than 10 envelopes to accumulate in the output tray. Always empty the output tray once 10 envelopes have accumulated.
    • You can select from the following paper sizes: <A4>, <A5>, <B5>, <Custom Size>, <COM 10>, <Monarch>, <DL>, <ISO-C5>, <ISO-B5>
    • The following envelopes can be loaded into the multi-purpose tray:
    • #10 (U. S.) 4.13 x 9.5 in. 3.73 x 8.95 in. .2 in. .275 in.
      #6 3⁄4 (U. S.) 3.65 x 6.5 in. 3.25 x 5.95 in. .2 in. .275 in.
      Monarch (U. S.) 3.875 x 7.5 in. 3.475 x 6.95 in. .2 in. .275 in.
      C5 162 x 229 mm 152 x 197 mm 5 mm 7 mm
      25 mm
      DL 110 x 220 mm 100 x 206 mm 5 mm 7 mm
      Choukei 3 Gou 120 x 235 mm 110 x 221 mm 5 mm 7 mm
      Choukei 4 Gou 90 x 205 mm 80 x 191 mm 5 mm 7 mm
    Set the service mode as follows:
    COPIER>OPTION>BODY>ENV-SPD from 0 to 1
    ; this runs the envelope at plain paper speed when the envelope setting is selected.
    0=half speed
    1-normal speed
    This service mode setting was introduced with System Software v65.01.
    The following are the recommended --Run at normal speed if envelopes are sticking--
    • Vegas10128
      • Jan 2017
      • 9
        25 mm
      0=half speed
      1-normal speed
      Perfect! Thank you very much,
