Ir 3025
  • bineeshgeorge
    • Jul 2009
    • 107
    Ir 3025
    Hai, friends ,what is the reason ? laser unit and drum replaced but no result.
    Sent from my HTC Desire X dual sim using Tapatalk
  • raman
    • Jun 2008
    • 6
    Re: Ir 3025
    Prints looks wavy from leading to trail edge. Grounding contact on steel registration roller may cause poor contact. Replacement of leaf spring (Part number FC5-1564-000) resolve the problem.
    • hitech
      Re: Ir 3025
      I recommend lubricating registration roller shaft inside the bushings. Recently had a senior tech show me the same issue, and he said that took care of the problem. Was that LTR or LTRR? If LTRR disregard as my comment wouldn't make sense.
      • jper34
        • Sep 2011
        • 225
        Re: Ir 3025
        how about if you run an internal test print...just to eliminate anything in the scanner..
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5006
          Re: Ir 3025
          I have this problem long time ago.If i remember i swap complete right door from another 3025 crap and it's work.Probably grounding issue.
          • techandtrader
            • Jun 2016
            • 330
            Re: Ir 3025
            ​Why not the registration clutch?
            I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
            • Canuck
              Tech Specialist
              • 1713
              Re: Ir 3025
              Remove the ground clip Raman showed. Bias it inward against the roll after cleaning it with sandpaper and applying black conductive grease to it. Never oil it for a squeak. Re-install it. The roll generates electrical noise to the Dcon which controls laser driver. Seen it many times...sometimes machine will log laser errors...E100,E110
              • techandtrader
                • Jun 2016
                • 330
                Re: Ir 3025
                thanks for that post. I have found a couple of those making annoying noise due to low grease. Always caught them and lubed them up quick with die electric. That's really wild that clip can do that! : )
