Canon 7260 Error codes
  • tekkie
    • Mar 2011
    • 111
    [Error Code] Canon 7260 Error codes
    Canon ir adv 7260 errors every time on power up with 2 error codes
    E260 and E227
    I have changed the AC power supply and the relay board everything points to the 24 v dc power supply its on order has anyone had same issues
    • 16083
    Re: Canon 7260 Error codes
    E260 and E227
    did u check voltages on 24V DC Power Supply.
    what are the e227 / & e260-xxxx sub codes
    • Rachid.Akli
      • Oct 2011
      • 595
      Try to measure the 24V input/Output on the relay PCB. If no input, replace the corresponding 24V PCB. If all the 24V inputs are ok, Verify the rlay 24V outputs.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
