Error showing E-015-60
  • +919567474622
    • Aug 2025
    Hi,
    I am facing a problem with IPR c6010,machine is showing a errorE-75-001
    i removed ITB then I cleaned lower and upper sensor ,rollers then I put it back ITB then I switchOn the machine machine is ready and printing after a 100 sheet printed machine is going to paper jam ,I removed all jammed papers after that machine is showing Warming Up longtime ,then machine will showing E 015-60
    I checked and cleaned the skew motor sensor changed paper type and also the papers but same
    Right now machine is down I waiting the valuable reply as soon as possible
  • stiftler
    Re: Error showing E-015-60
    You might want o initialize the ITB. However your image location/size settings might be affected.
    Service mode - copier - Function - Install - Init-ITB
