4235 dusting towards left side of paper path
  • Jerrygbs
    • Dec 2008
    • 194
    [CQ] 4235 dusting towards left side of paper path
    replaced drum to correct copy quality, new drum same issue
    auger in drum turns freely , developer clean nice curl. no buildup either side .
    anyone seen anything like this?
  • rudysemira
    • Oct 2016
    • 108
    Re: 4235 dusting towards left side of paper path
    Attach the sample...
    • Jerrygbs
      • Dec 2008
      • 194
      i don't have an example on hand, but i would like to add that the drum unit didn't have any waste toner in the auger section, this is an aftermarket/non canon manufactured drum.
      • rudysemira
        • Oct 2016
        • 108
        Do you use original toner? sometimes it is causing dusting on copy if the original and non-original mixing the quality not fine......
