Error E000-0000 on iR 2004 printer (Urgent)
  • Biv
    • Apr 2017
    • 8
    [Error Code] Error E000-0000 on iR 2004 printer (Urgent)
    How to fix E000-0000 error on canon iR 2004 printer? Everyone are saying to press Setting/ Registration (additional function) key to go to service mode on other canon printers but sadly this printer does not have setting/Registration key on the front panel. It has just status monitor, paper setting, ID card copy, back, reset, counter check, home, energy saver, start and stop buttons. Therefore how to go to service mode on this printer to fix E000-0000 error ? Pls help.
  • rudysemira
    • Oct 2016
    • 108
    Re: Error E000-0000 on iR 2004 printer (Urgent)
    Try this im not sure if this same for canon ir 2202
    1.press the setting key
    2.reset key
    3.back key
    4.setting key again
    take a look on display go to copier then go to function the clear.......hope this can help you...
    • Biv
      • Apr 2017
      • 8
      2.reset key
      3.back key
      4.setting key again
      Hi I have tried that on iR 2202 but the Setting key is not present on iR 2004 . It has 'paper settings' key instead on the front panel.
      • rudysemira
        • Oct 2016
        • 108
        did you try the paper key setting to press it?
        • Fundi Eddy
          ir2004
          SERVICE MODE
          imageRUNNER 2204N / 2004N / 2004
          Press HOME Key
          then_Press RESET Key
          then_Press BACK Key
          then_Press Home Key again
          (one press on each key)
          Brings up Service Mode Screen Menu
          • kanibik751
            • Nov 2021
            • 1
            This error is very old so new users can face problem to fix this error so you need to talk their customer care. You can also go here on another topics of this site and find their number. I am working in this translation service so if you need any help then tell me.
            • GIUBOSS
              • 1392
              You are replying to a post that has been buried for 4 years now, don't you think it's too late with the equipment thrown in the trash?
