Canon iR C3080i E067 - 0101 error
  • MFPTech
    • 486
    hi,
    This error is haunting me ...
    first time it happened I went on site with both Bk Drum and ITB. Replaced the Bk Drum but it did not fix it so I put the original drum back and replaced the ITB and the error went away....
    Did grad adjustments, tested the machine with print and copy - everything worked great! After I left the customer called back for the same error.
    Went back and replaced the Bk Drum and the error went away ... again, did grad adjustments, tested the machine with print and copy - everything worked great! After I left the customer called back for the same error.
    Any ideas please besides replacing this copier?
    Thanks in advance!
  • PCC.TONER
    • Mar 2017
    • 13
    Re: Canon iR C3080i E067 - 0101 error
    Originally posted by MFPTech
    hi,
    Thanks in advance!
    E067 - 0101 error, you can try as follow:
    Check on the primary transfer roller spring, Clean the position where the primary transfer roller contacts,
    Replace the primary transfer roller, Replace the drum unit Check a value of COPIER> DISPLAY> MISC> DRM-LIFE,
    and replace the drum unit if the value is near 100 because the drum may have reached its life expectancy.
    Linda.
    china spare parts, Toner chip, Copier parts, Toner Cartridge - einmay toner
      • 8133
      There was a system software fix for this issue, updating the DC-CON to version 66.02
      E067 fix.pdf
      • MFPTech
        • 486
        Thanks!
        Sent from my SM-G903W using Tapatalk
          • 8133
          Thanks!
          You're welcome
          • petermays
            • Mar 2017
            • 91
            #3 is correct.when you do lastest system firmware DC is updated to v65 what causes E067.you need to update dc only with V66
