need UFR2 driver for 3300i windows 7 32 bit and 10 64 bit
  • wild140
    • Feb 2017
    • 70
    [Misc] need UFR2 driver for 3300i windows 7 32 bit and 10 64 bit
    the driver package on Canon's public site for 7/32 bit does not list 3300 even though it is downloaded from that window.
    no UFR2 driver listed for 10/64 bit ?
  • Guest
    Re: need UFR2 driver for 3300i windows 7 32 bit and 10 64 bit
    Download the ufr2 for the ir adv C5560. That is the newest driver. Ufr2 is canons all in one driver.
    Sent from my SM-N920P using Tapatalk
    • wassem
      • Aug 2012
      • 166
      canon ir 3300i not support UFR2 its very old machine
      it supports only ps and pcl
      • sniper2g8
        • Jan 2013
        • 117
        Go to canon support website and search for it
        • wild140
          • Feb 2017
          • 70
          If you go to Canons website under windows 7 32 bit it lists a UFR 2 driver for 3300, when you download and try to set it up 3300 is not in the list, PCL was an option that had to be added to the unit , so somewhere along the way they must have had a UFR2 driver. Just not in that package ? , seems like an oversight .
          Perhaps one of us that has access to Canon's direct support can make a call ?
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Choose any model from the list.Set IP and ready to go.
            • wild140
              • Feb 2017
              • 70
              Tried the just pick one method when I first discovered 3300 was not on the list , tried a few different models , Got AKSI keys and hieroglyphics which means the driver was not correct . This is off of the public site . no access to CUSA tech site.
              • teckat
                • 16083
                Originally posted by wild140;56041[HR
                [/HR]8]Tried the just pick one method when I first discovered 3300 was not on the list , tried a few different models , Got AKSI keys and hieroglyphics which means the driver was not correct . This is off of the public site . no access to CUSA tech site.
                There is no UFRII driver for 3300I
                • copier tech
                  • 8174
                  Being such an old machine the IR3300 is in the Windows driver 7 database, just choose Canon from the dropdown box then IR3300.
                  If that doesn't work choose the Windows update option however as mentioned above UFR is not supported on the IR3300.
                  • wild140
                    • Feb 2017
                    • 70
                    And the answer is , PCL-5e works. PCL 6 does not .
                    Thanks all for the suggestions and assistance
                    • Canuck
                      Tech Specialist
                      • 1713
                      Yes on the older models if you had a print kit installed, you printed either PCL or emulated PS. Newer ones all print UFRII...you need to buy PCL. On new new new ones...lol...PS included
