Canon NP 6260 Error 002
  • sgcopiertech
    • Jul 2025
    good day
    i have an NP 6260 with E002
    so far i have changed the ff parts but to no avail:
    heater unit
    power supply
    dc controller
    ssr
    any body have any suggestions?
    thanks!
  • mjarbar
    Hello,
    I would also check to see if there is any sort of gap between the thermoswitch and the fuser roller as this will also cause the E002 code to remedy this it is a simple adjustment, also once you have changed the parts you still have to clear the error code in the service screen, as you have not said if you have done this or not I have included the procedure below.
    Best of luck.
    • sgcopiertech
      error
      i have changed the whole heating unit already
      the error is intermittent.
      the temp will go up from room temperature
      it will go until 130+ then the error will come out.
      once you reset the error code
      you will be able to use the machine for awhile
      until the error comes again.
