Canon clc3200 red color is orange
  • Salonpixel
    • Feb 2017
    • 18
    [Misc] Canon clc3200 red color is orange
    Hello forum guru from Russia with love and hope!
    After much suffering, I managed to run my Canon clc3200.
    When printing, the red color turns orange.
    But when you print a test page with a postscript, the red color is printed normally.
    Tried to change profiles, settings, but nothing helps.
    In which direction to move? What do you advise, great experts?
    With respect, Alexander.
  • teckat
    • 16083
    Re: Canon clc3200 red color is orange
    https://schneider.ncifcrf.gov/postscript.html
    do u have an external Fiery Controlled connected on back of printer ??
    Multi PDL Network Printer Unit-C1 (Optional)
    Canon's optional Colour Network Printer Controller (POST-RIP CALIBRATIONPost-RIP calibration from ColorWise™ isintegrated in the Print Controller.)
    http://help.efi.com/cws/5.7/en-us/GUID-79E8E1CA-A260-461B-A2EB-2E70C33A53E1.html
    What do the AUTO CALIBRATION pages ( run from control panel ) colors look like
    see post link below
    http://www.copytechnet.com/forums/ca...n-problem.html
    • Salonpixel
      • Feb 2017
      • 18
      Tank you for answer and links, dear teckat!
      I respect you for you skills!
      Yes, i have imagepass-c1.
      But the problem was with magenta drum. It seemed to me that on tests red was normal, but it was not so.
      After replasement color turned red.
      I have another problem:in menu "Adjustment/Cleaning" only one selection - cleaning of indoor unit.
      Sorry for my bad english.
      This Canon is my first laser printer) he was wery bad. This forum, and you and balamuta very helped me.
      • teckat
        • 16083
        that user mode is a waste--
        User Mode Items
        Adjustments and CleaningBest to go into Service Mode Level 1
        COPIER>FUNCTION <CLEANING>
        Used to execute cleaning operations.//if needed
        TBLT-CLN
        FDRL-CLN
        Used when cleaning face-down paper delivery roller 1/2.
        Operation:
        1) Select this item, then press the OK key to start the rollers operating.
        2) While both rollers are operating, press against each with a cloth soaked
        in alcohol to clean it.
        3) Press the stop key to stop the rollers.
        RVRL-CLN
        Used when cleaning reverse roller.
        Operation:
        1) Open the paper delivery cover.
        2) Select this item and press the OK key to start the roller operating.
        3) While the roller is operating, press against it with a cloth soaked in alcohol to clean it.
        4) Press the stop key to stop the roller.
        DEVL-CLN
        Cleans inside developer unit.
        Image imperfections are improved by forcibly consuming toner that has been over-agitated (toner with improper charge) by the toner agitation
        screw.
        Operation:
        1) Select this item and press the OK key.
        2) The cleaning operation lasts about 160 seconds, then ends automatically.
        also in COPIER>FUNCTION >FEEDER>FUNCTION
        SPRL-CLN
        Enters separation roller cleaning mode.
        Operation:
        1) Place white paper in the document tray.
        2) Select this item, and press the OK key.
        REG-CLN
        Enters registration roller cleaning mode.
        Operation:
        1) Close the ADF, and check that the paper feed unit cover and reverse paper delivery unit cover are closed.
        2) Select this item and press the OK key.
        3) Open the paper feed unit cover, and press against the registration roller lightly with a lens paper or cloth soaked in alcohol. (The roller operates
        for about 40 seconds.)
        Note: During the operation, the roller stops if you close the paper feed unit cover, or open the reverse paper delivery unit cover or ADF.
        time for a manual-------------------https://www.scribd.com/doc/61327440/Canon-Irc3200-Service-Manual
        • Salonpixel
          • Feb 2017
          • 18
          Wery big thanks, dear teckat!
          Adjustments and Cleaning menu have only "cleaning inside machine".
          How to return the rest of the items?
          • teckat
            • 16083
            • Salonpixel
              • Feb 2017
              • 18
              • teckat
                • 16083
                [ATTACH=CONFIG]36556[/ATTACH][ATTACH=CONFIG]36557[/ATTACH][ATTACH=CONFIG]36558[/ATTACH]
                Do you have a PRINTER Only Model (has no platen glass)
                that would explain the missing selections that are used only when you have a full printer/copier ( as in auto gradation--zoom and other ).
                If u do have copy glass---Other models or series may not have this adjustment settings.
                CLC3200 is slightly different than iRC3200
                • Salonpixel
                  • Feb 2017
                  • 18
                  Yes, this is printer only : о
                  Today I tried all day to adjust the color rendition, but not much happened.
                  Tomorrow I'll try to show all the tests from the printer (test 10, test 5) and show problem with color rendition.
                  I will say briefly - the print turns out to be too dark and inaccurate in terms of color rendering.
                  I have not service Canon in my sity, and i need help.
                  Dear teckat, thank you for your help! Bigest respect you!
                    Product : imageRUNNER C2620 / C3200 / C3220 / C4080 / C4080i / C4580 /
                    C4580i C5180 / C5180i / C5185 / C5185i
                    Title :
                    Blues are coming out Purple and Reds are coming out Orange
                    Problem :
                    Blues are coming out Purple and Reds are coming out Orange. Replacing the Drums,
                    doing Auto Gradation and Calibrations does not help.
                    Solution :
                    Replacing the machine's Hard Drive will correct this issue. Either install a new Hard
                    Drive, use a Hard Drive from another working machine or format and reload SSW on
                    the original Hard Drive.
                    (I don't have access to firmware)
                    • Salonpixel
                      • Feb 2017
                      • 18
                      SkyNet, thanks, but replacing the drum unit has solved this problem. Now I have a bad color transfer.
                      It is very difficult for me to write in English, so I will show scans of prints tomorrow.
                      Thank you for your patience and help!
                        Great we are here to help.
                        • teckat
                          • 16083
                          * Note - On copiers that are printer-only models (no platen glass), the CC-100 utility will be needed to perform the auto gradation adjustment.
                          Canon CanoScan 3000F or 3200F scanner 9 or added
                          Canon CanoScan LiDE35 )
                          is required to use the CC-100 utility.
                          see link for CC-100 Utility
                          https://www.dropbox.com/s/53ub3gr4n8...v2.85.exe?dl=0
                          If you do not have the CanoScan 3000F ot 3200F ( very old scanner ) available, there is an alternate method that can be utilized.
                          This method will cause the copier to lose many of your settings (and stored jobs). You can do a HD Clear by following the steps below:
                          1. Go into Service Mode, by pressing Additional Function, 2 and 8 simultaneously, and then Additional Function again.
                          2. Select COPIER.
                          3. Select FUNCTION.
                          3. Select SYSTEM.
                          4. Select CHK-TYPE=[1].
                          5. Select HD-CLEAR.
                          The following information will return to factory defaults as a result:
                          • User mode settings
                          • Job log
                          • PDL fonts
                          • PDL form data
                          • ICC profile
                          • Macro data
                          • mailboxes
                          • Is there an alternate calibration method (other than the CC-100 utility) for printer only units if you have an imagePass C1 attached?
                            Answer :
                            Yes, you can use VisualCal available in the imagePass C1's calibration utility menu.
                          • Follow the steps below to access and perform VisualCal:1. Access the Printer window in the copier display.
                            2. Select Functions in the imagePass C1 window.
                            3. Select the Calibration menu.
                            4. In the calibration menu select Set Up Calibration / Expert / VisualCal, then in the VisualCal set up select either Auto Select or Manual Feed as paper source.
                            Now you can begin the calibration process.
                            In the Printer / Functions screen select Calibration, then choose either Default, Custom A, or Custom B. Then in the Gradation Smoothing screen select Off, Fine, or Course. In the Print Limits Page screen select Yes.
                            The VisualCal limits page will print. Follow the steps on the Print Limits VisualCal page to perform and complete calibration.
                          • Salonpixel
                            • Feb 2017
                            • 18
                            O, teckat! Thank you very mach! I'll start with resseting hdd.
                            Tell me, can there be a reason for poor printing of low humidity?
                            My humidity is 25%. Its very low?
                            • teckat
                              • 16083
                              before messing with HDD
                              try the VisualCal
                              1. Check to make sure that the toner save mode is OFF on the image-pass C1
                              2. In your case--run some internal test prints in service mode
                              3.
                              You may want to delete then reload the print drivers
                              4. if
                              your test pages are all fine from the image pass and internal test pages./
                              try
                              looking at the print drivers and default settings within the print driver.
                              if internal test prints are light-----make sure your ITB UNIT is locked up in position (
                              look at manual-------------for instructions on how to print internal test prints
