Tnks!
I will inspect ITB.
Say me please, cyan in the test 10 very bad? The developer is died? ) Or charge roller is bad?
I also looked at the humidity - it was 15%.
Can the relative humidity influence the loss of color?
Tnks!
I will inspect ITB.
Cyan drum could be old. The four primary charge rollers are in the ITB UNIT,
Humid conditions effect paper, & toner.
If that is what we call irc3200 here, yes, red comes out orange on them unless you hook up an Imagepass or Colorpass. You can calibrate until you are blue in the face but still come out orangish...unless you get a RIP.
Great reply on color remember way back on the iRC3200 using that CA-7 color chart---red patch >>Yellow+ Magenta = Orange= Japanese see a different RED
Canon CA–7 TEST SHEET_A test sheet is a piece of cardboard with precise markings that are designed to allow for particularthings to be measured or checked.By making a photocopy of a test sheet you can check for items such as focus, paper leading edgetiming, distortion, centering, overall density and skew. see link for chart http://www.soxtraining.co.za/resourc...structions.pdf
I repaired it! I completely cleaned the drum unit, cleaned the magnetic shaft, photoconductor, charge roller.
I cleaned all contacts. The new developer fell asleep and the printer began to print normally!
Thank you for your help!
There remains one problem - I can not find the PS driver for Windows 7 x64, only PCL drivers are available. I repaired it! I completely cleaned the drum unit, cleaned the magnetic shaft, photoconductor, charge roller. I cleaned all contacts. The new developer fell asleep and the printer began to print normally! Thank you for your help! There remains one problem - I can not find the PS driver for Windows 7 x64, only PCL drivers are available.
PCL Printer Driver v15.00 Setup Installer for Windows XP/ Vista/7/8/8.1/10 Server 2003/ Server 2008/ Server 2008 R2/ Server 2012/ Server 2012 R2/Server 2016 (WHQL certified) x64bit. This driver adds support for Windows Server 2016, XenApp 7.5 and XenDesktop 7.5. PACKAGE-AWARE PRINT DRIVER - PLEASE READ 'RELEASE NOTES' BEFORE INSTALLING THIS DRIVER!
File name
PCL6_v15.00_Set-up_x64.exe
PCL_v14.02_x64.exe
01/09/17
25.0 MB
CLOSE
PCL Printer Driver v14.02 Setup Installer for Windows XP/ Vista/ 7/ 8/ 8.1/10 Server 2003/ Server 2008/ Server 2008 R2/ Server 2012/ Server 2012 R2/Server 2016 (WHQL certified) x64bit. This driver adds support for Windows Server 2016, XenApp 7.5 and XenDesktop 7.5
File name
PCL_v14.02_x64.exe
