ir2200/ir2200n SST error 124
  • ids_73
    • Jun 2011
    • 16
    hi there
    i am using SST ver4,81e and i am trying to install the firmware but i am getting an internal error 124 whatever i try to pass from pc to ir any ideas?
    i have attached a screen shoot of it
  • copier tech
    • 8101
    Re: ir2200/ir2200n SST error 124
    Originally posted by ids_73
    hi there
    What HDD are you using?
    • ids_73
      • Jun 2011
      • 16
      hi there,
      i have used many deferent hd
      IBM dmca-21080 1080mb
      IBM DARA-218000 18gb
      hitachi travelstar HTS548040M9AT00 40gb
      toshiba MK6014MAP HDD2144
      and all of the they give me the same error message
      the one that i had to replace was a HITACHI Travelstar IC25N020ATMR04-0 20GB
      • songela
        • Mar 2008
        • 216
        If you are using USB to Parallel interface you are likely to face challenges.
        That model work better with Bicentronics cable.
