Canon ir C5030 Shading Black Text
  • maximilian500
    • Aug 2016
    • 67
    Hello everybody,
    I have been here for months, a problem with which I annoy myself. It is an IR C5030i which only appears in black text shadow behind the text. This problem now almost every day on. All other colors do not have this problem. I have already been replaced:
    -ITB foil and cleaning blade
    -black drum
    -cleaned Laser Unit
    Can these errors also come from old toner?
    I would not like to replace the very expensive development unit.
    In the appendix the pictures to the problem.
  • copier tech
    • 8179
    Re: Canon ir C5030 Shading Black Text
    Are you using Genuine Canon toner?
    • maximilian500
      • Aug 2016
      • 67
      Yes I use Canon Genuine Toner. But I do not know how old the toner is.
      • copier tech
        • 8179
        Unusual to have "old" toner causing an issue, unless it has been stored above or below the recommended temperature conditions.
        However looking at your sample I cant see any issues with the print quality!?
        • maximilian500
          • Aug 2016
          • 67
          When you look at the blue Box in the Text: Bei Problemen mit organisatorischen Angelegenheiten... you will see strayed toner around the letters.
          • maximilian500
            • Aug 2016
            • 67
            The error is particularly noticeable with the letter e
            • maximilian500
              • Aug 2016
              • 67
              I have shown the error here again more clearly. It is as if dust were around the letters. I changed today the black toner against new. Also interesting is that the error no longer occurs on the whole page.
              Here is an example of how the error looks. Here is an example of how the error looks. Especially at the top line, the dust around the letters can be seen.
              • guitar9199
                • Sep 2016
                • 1100
                How many copies/prints on this machine?
                • maximilian500
                  • Aug 2016
                  • 67
                  Machine has 216000 printouts.
                  Is it possible to readjust the laser? I know this only at Konica, which goes there in the service menu. But how is this done with Canon?
                  I have ordered a new complete fixing unit. It's just funny that only black is smeared from the fuser.
                  • duwaynebrooks
                    • Aug 2015
                    • 43
                    Looks like a font issue.
                    Have you tried changing dpi ?
                    • maximilian500
                      • Aug 2016
                      • 67
                      I changed the Fixing Unit with a new one. Now the error is gone away.
                      • maximilian500
                        • Aug 2016
                        • 67
                        Hello everybody,
                        The error is back. So slow really annoying. Meanwhile I have changed:
                        -the black drum
                        -ITB
                        -Fixing Unit
                        The error is not now on the entire page, but now affects only single letters which are printed in black.
                        Does one have yet another idea what can cause the problem?
                        Thanks for replies
                        • copier tech
                          • 8179
                          You have changed everything but the black dev unit!?
                          What is the life showing?
                          • maximilian500
                            • Aug 2016
                            • 67
                            The Developer have 45 percent life.
                            • zoraldinho
                              teacher-guide-expert-guru
                              • Mar 2008
                              • 5015
                              It's smel's like not enough black developer powder in the unit.Check values or replace black developer.
