RSOK service login
  • Copierdocisleofman
    Senior Technician
    • Aug 2009
    • 86
    RSOK service login
    Hi, I am trying to access the service mode on a Canon device through the RSOK. I have tried pressing "u" on my keyboard then pressing 2&8 simultaneously then "u" again but this doesn't log me in. Has anybody had any experience with this?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: RSOK service login
    RSOK service mode:
      • 16083
      Originally posted by zoraldinho
      RSOK service mode:
      [ATTACH=CONFIG]36855[/ATTACH]
      RSOK
      Remote Operator's Software Kit
      Remote Operator’s Software KitThe optional Remote Operator’s Software Kit provides alternative access forusers with mobility or dexterity impairments.
      This software emulates theimageRUNNER control panel and hard keys on a computer screen, therebyallowing users to operate all system functions–including copy, print, fax,scan, and send–from a network-connected computer.
      https://www.usa.canon.com/internet/p...s-software-kit
        • 16083
        imagePRESS / imageRUNNER ADVANCE
        How-To access Service Mode Via Remote Operation Kit
        see attach
        • zoraldinho
          • Mar 2008
          • 5015
          Originally posted by teckat
          RSOK
          RSOK
          • zoraldinho
            • Mar 2008
            • 5015
            see attach
            Easy to remember.
            • hdmr
              Helpdesk Engineer
              • Feb 2013
              • 51
              New to Canon
              I have used RSOK but I cant remember if the feature needs to be enable on the device or is it just pop in IP address and away it goes?
              RSOK
                • 16083
                There are a few things needed to use the Remote Operator's Software Kit.
                1. Verify the Remote Operators Kit is installed.
                2. Enable the Remote Operators Kit.
                1. First, you will need to activate the Remote Operator's Kit by entering the License Key or installing the .lic file via the RUI.
                To verify the Remote Operator's Kit is installed, press Counter Check, press Check Device Configuration, scroll to the Options and look for the Remote Operator's Software.
                If it is listed, then we should be able to connect. If the kit is not listed, please get the LAN and register online to obtain a License Key. Then enter the License Key on the imageRUNNER ADVANCE.
                2. Next, you will need to enable the Remote Operators Kit.
                1. Press Settings/Registration.
                2. If Management Settings is greyed out, then Login as System Manager.
                3. Press Log In, Enter in System Manager ID and Pin. Press Log In.
                4. Press Management Settings > License/Other > Remote Operation Settings, make sure set to On. If you want to use a password, enter a pw and press OK, then Close.
                Make sure to reboot the imageRUNNER ADVANCE for this to take effect.
