5030 all color toner sticking to heat sleave
  • Jerrygbs
    • Dec 2008
    • 193
    all colors/ when doing gradation adjustment stick to fuser. adjusted fix temp, swapped fuser, replaced all drum/ developer. gave temporary fix, ran few weeks clean, then developed same issue.
    client now has a loner machine
    changed power supply board AC driver PCB (un6) ,AC sub driver PCB (UN7) same issue,htv1/2 same issue
    waiting on main board /dc controller pcb un1, pcb2,main controller pcb1,
    any help would be greatly appreciated
  • dan7777
    • Dec 2012
    • 680
    Re: 5030 all color toner sticking to heat sleave
    Had that once. I forgot to change out that guide FC8-5043 and move it to the new fixing film. I was convinced I got a bad fixing film. Only time I did that. Would feed black ok but jam on color. One of the many slap forehead moments.
    • Brian8506
      • 1665
      I've had that and it was bad toner. Replacing the developer unit helps but there is still contaminated toner in the hopper and that end up contaminating the developer and it comes back again. Change DV and pull hoppers out and vacuum out.
      • copier tech
        • 8169
        Classic pirate toner issue.
        You can monitor the fuser temp in service mode so can rule out heat issue (you would get an error code if the temp dropped too low anyway)
        • Brian8506
          • 1665
          My cases were all OEM toner. Never used generic in a color machine.
          • Drcopy
            • Jan 2017
            • 57
            Agree with the non genuine toner, also upgrade the firmware.
            • cscce
              • Jun 2014
              • 156
              I've heard of some counterfeit "Genuine" Canon toner. Do the toner boxes have the holographic Canon sticker on them?
              • klounz
                • Jun 2009
                • 5
                Are you using OEM toner?
                • Brian8506
                  • 1665
                  Mine did
                  • dan7777
                    • Dec 2012
                    • 680
                    Originally posted by Brian8506
                    Mine did
                    Had a 7260 with bad black toner the lady ordered online (very cheap too). It would not fuse. Colors ok. It had the sticker but looked suspicious. I agree you have to vacuum the hopper.
