I am no Canon expert, so please enlighten me!
This machine has streaks coming from (what appears to be) a defective Transfer Belt Blade. I normally would not be inclined to replace ONLY the blade, but wanted some advice on what to do. Should I be replacing the entire Belt, etc. and rebuilding it all? Or just go with the Blade?
Also, is there an easy way to pull the Belt assy out, procedure, etc?
Thanks in advance,
OC
Thanks in advance,
OC
