After printing in service mode about 50m2 canvas, I noticed that ink stays in same position without calculating consumed ink. Is there a way in service mode to change ink level on Canon 8300?
Canon IPF 8300
Re: Canon IPF 8300
The machine calculates ink usage based on the number of times the printhead nozzles actuate. Can you count the number of bubbles of ink on the page? I sure can't. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Re: Canon IPF 8300
I definitely don't understand. If you think that the machine is not properly calculating ink levels, exactly how will you determine what the correct ink level is? That's assuming that that information can be "programmed" (and it probably can't be). Do you realize that 50m2 is not very much paper or ink (assuming a 3' wide roll x ~55')? Perhaps it has not changed significantly yet.
"a) The ink level in each ink tank is memorized in EEPROM attached to the tank and is detected as a dot count on the basis of the EEPROM information.When an electrode attached to a hollow needle detects no continuity, it displays a message reporting that the ink tank is nearly empty.If the dot count reaches a predesigned value in this state, an ink out condition is assumed."
Re: Canon IPF 8300
As the heads age in these machines, they will have to use more ink to keep the head from having clogs and head errors...
Try updating the F/W on the machine - end users can do it.
If you squeezed over 750 days - which is over 2 years - for one of these heads without having problems, then congrats.Comment
