E025 0400 New iRADV55 series
  • markyj
    • Jan 2016
    • 7
    [Error Code] E025 0400 New iRADV55 series
    Hi Has anyone else has problems with this. We've had 4 of these machines give the same error code intermittently. It's related to rotation error of the black toner bottle. The manual suggests ultimately swapping the toner hopper assembly.
    Re: E025 0400 New iRADV55 series
    what have you tried so far?
    • markyj
      • Jan 2016
      • 7
      Replaced toner cart, turned the drive gears by hand, cleaned/reseated connectors and sensors. I've ordered a hopper unit for one of the machines and will see how that goes.
      • macuk
        • May 2009
        • 90
        Hi,
        I know this is an old post but, did you ever get a solution to your problem? I have 4 machines out of 11 that have started doing this as of Friday. Thanks
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          My machine fixed this by replacing the toner hopper
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
