Canon 4245 lock screen
  • teklife256
    • Sep 2012
    • 164
    Happy Monday all. Working ona 4245 today with a lockes startup screen. On friday it was locked up at the startup screen. Today there is only the white trail on the bottom of a black screen . No codes and machine is unresponsive. This canon is a one off in our fleet and im not very familiar with it. Any help would definetly be appreciated
  • kuby
    • Oct 2007
    • 1409
    Re: Canon 4245 lock screen
    Sounds like the hard drive may be going out. You can try running the scandisk feature in the Canon. Most of the Canon's I've seen have this feature, you press and hold 1+9 until you see little white boxes coming from the top of the screen to the bottom.
    • teklife256
      • Sep 2012
      • 164
      Originally posted by kuby
      Sounds like the hard drive may be going out. You can try running the scandisk feature in the Canon. Most of the Canon's I've seen have this feature, you press 1+9 at start up.
      Gave that a try and no response. I think that I can dig up the manual but do you have any tips for replacing the hard drive?
      • Brian8506
        • 1665
        The cpu board in the control panel can go bad and I believe that is the symptom. I don't think it's that expensive
        • Canuck
          Tech Specialist
          • 1713
          Control panel cpu pcb...FM1-C888....changed many. When its frozen see if you can doing anything thru RUI. If RUI has no problems,its this board
