ImagePress 7000VP error code 000015-0110-05
  • Lindac
    • May 2025
    [Error Code] ImagePress 7000VP error code 000015-0110-05
    Getting an error code 000015-0110-05 when booting up the machine. To make a long story short. Booting up the machine and got an error that one of the doors or levers weren't latch. Machine pointed to the primary fuser. Unlatched, pulled out and relatched. Now the machine boots up with the above error code. When the fuser is disengaged, the machine boots up to the point of a latch needs closed. Does anyone know if it is a fuser or sensor issue. Can someone tell me what this code is pointing to and more importantly how to fix it?
  • teckat
    • 16083
    Re: ImagePress 7000VP error code 000015-0110-05
    E015 = Error in feed related roller position control
    0x10 Error: flapper position control
    The change of the position control sensor cannot be detected even when a specified period elapsed after the
    start of motor driving.
    1. Check if the connector at fixing flapper motor (M309) and delivery reverse flapper motor (M319) is disconnected/ not securely inserted -> disconnect and then connect the
    connector
    2. Replace the fixing flapper motor and delivery reverse flapper motor
    x=
    1: Fixing path (tandem/bypass)
    2: Delivery reverse flapper
    • Kwaku01
      • Aug 2018
      • 121
      Please Help!!! How did you get rid of this error. I'm having the same issue...Please Help!!!
      • Kwaku01
        • Aug 2018
        • 121
        Solved! Tnx
        • teckat
          • 16083
          Solved! Tnx
          what steps did u follow
            fix was explained.
            • teckat
              • 16083
              fix was explained.
              By who ?
              • Kwaku01
                • Aug 2018
                • 121
                Followed step 1 and it worked. Tnx
                "1. Check if the connector at fixing flapper motor (M309) and delivery reverse flapper motor (M319) is disconnected/ not securely inserted -> disconnect and then connect the
                connector"
                  By who ?
                  By you Sir.
                  Rep Power223
                  connector
                  x=
                  and the OP said he tried your suggestions and it is now operational. Good Job!
                  • teckat
                    • 16083
                    By you Sir.
                    Rep Power223
                    connector
                    x=
                    Getting Old 😱
                      Getting Old 😱
                      for me thats not the hard part..... remembering where I put my keys and wallet are starting to become a problem.
                      Me thinks Toby Keith had the right way to put it " I ain't as good once was,
                      But I'm as good once, as I ever was. "
