Canon ir3245 Ghost printing or double image printing problem
  • ss.xerox.print
    • Aug 2025
    [Error Code] Canon ir3245 Ghost printing or double image printing problem
    I dont know what to name this problem , getting double image printing pls help me to solve this issue .. i have attached 3 different images of the printing ..i have changed new drum n charging roller as well..Thanks
  • dan7777
    • Dec 2012
    • 680
    Re: Canon ir3245 Ghost printing or double image printing problem
    It looked like fuser at first but your last copy is half good. Maybe main controller at guess. I was going to suggest turn the heat up until I saw the last sample.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      He he.Me too!
      Probably messed up with controller or laser unit.
      • ss.xerox.print
        will ths be the power voltage issue?
        • ss.xerox.print
          Originally posted by zoraldinho
          He he.Me too!
          laser unit is good.. controller in the sense which one??
          • dan7777
            • Dec 2012
            • 680
            I doubt it could fix it but on that model you can update the software with a usb thumb drive. Now at 49.02. I don't think power would be an issue unless you have no ground or bad ground and there is a lot of voltage on the ground line. I don't know where you are or what your power is. Lots of people here are from all over. I was guessing at the main controller. Not sure but that model may only have one, some advanced models have a couple. The scanner is another possibility, I have had problems with those on that model, usually strange issues.
            • SMART TECH
              How is the internal print ? if ok then check the scanner cable /connector.
              • Jasbeer0129
                • Dec 2022
                • 1
                I am also facing same issue but when I reinstall drum unit it work fine for some time.. u can clean a strip placed led on it when u remove drum unit n dp. U will see that strip..
                • Venom
                  Technical/IT Support
                  • Nov 2009
                  • 765
                  Try another drum unit, i had one doing the same.
                  IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                    this thread is 5+ years dead.
