ir 5000d
  • smiley
    • Aug 2008
    • 615
    ir 5000d
    hi to all i have a problem on this machine ir 5000d first the hard disc broke then i replace it with ir5000dn hdd but the machine just boot up only in the middle then it never continue. no error code apear.please help me.
    there is no glory without sacrifice
  • BLITZKREAGG
    IR 5000DN
    The reason it won't work is because the hdd for the 5000dn wont work in the 5000d because canon wants you to have to buy the print kit for the 5000d but the 5000d hdd will work in the 5000dn machine
    • smiley
      • Aug 2008
      • 615
      how about the hdd of 5000n to 5000d?
      • BLITZKREAGG
        IR 5000DN
        I believe the same concepts apply as i stated above, canon wants you to but the $1500 print kit to change it to a networked machine
        • smiley
          • Aug 2008
          • 615
          ok thanks for your advice.
          • Paul 75
            • Oct 2008
            • 97
            Its not the hard drive its the software that your loading onto it. You have to load 5000d software onto the hard drive not 5000dn - dn is the postscript version, format the drive and put 5000d system onto it and you should be ok. If you put anything else on it clashes with the bootrom
            Oh...... I can't copy at the moment then ? !!!!!!
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Agrees with Paul ^_^
              • smiley
                • Aug 2008
                • 615
                thanks paul and oze. im realy wondring what printer kit i going to put on 5000d to run it as network machine.all i know is to flash the bootrom and a system with ir 5000 version that has n.
                • pelala
                  • Aug 2012
                  • 10
                  Re: ir 5000d
                  can I flash the bootrom from ir5000d to ir5000n to make it to work as network
