frim ware
  • imran181070
    • Aug 2016
    • 24
    [Misc] frim ware
    have a machine irc 2550 it gave E602-001 put a new HDD cant format or put firm error
    pls need instruction from any old copier expert
    thanks
  • BtPavic
    • May 2015
    • 3
    Re: frim ware
    Hello this message will be if HDD serial number isnt on the sst filter list...try to modificate list..
    • copier tech
      • 8174
      Re: frim ware
      First did you fit a Canon HDD or just any one? It needs to me the correct one or you wont be able to install the system software. I buy an identical one from eBay.
      Next you install the firmware onto the SST tool, create a USB boot stick put this into the copier, start the copier in safe mode then you get the option to format & install the software.
      • Alfons
        • Sep 2016
        • 9
        Re: frim ware
        Try to add in the list the P/N of your new HDD (not the serial number). I did this on a iR2200 some time ago. I changed the file " iR2200-XXxx0013-HDFormat.ift". Good luck !
        • copier tech
          • 8174
          Re: frim ware
          ^^^^ This will only work on the old IR2200/3300 it is not possible on later machines, the system software is encrypted & cannot be modified!
          • Canuck
            Tech Specialist
            • 1713
            Re: frim ware
            Not necessary to install to USB...just install it to copier through crossover cable and SST
            • techwurk
              • 127
              Re: frim ware
              This was the last series mach you can edit the IFT, not possible on the mach he is working on due to encryption
              When I started servicing copiers they used toaster ovens for fusers.....I'm old
              • teckat
                • 16083
                Re: frim ware
                thanks
                u need OEM Canon HDD----------
                a SATA HDD will require additional hardware to fit in product
                see attachment--------- Adoption of the SATA Hard Disk Drive
                FM4-4379-000 1 HDD, WD800JB PATA HDD
                CZG,CZS,CZU,DBC,DBM
                FK2-8352-000 1 HDD, ST3160316CS SATA HDD
                CZH,CZJ,CZK,CZR,CZT,\nCZY,CZZ,DAH,DAZ,DBB,
                \nDBD,DBE,DBF,DBG,DBN,\nDBT,DBU,DBV,DBW,DBX,
                \nDBY,DBZ,DCA,DCE,DCF,\nDCK,DCL,DCM,DCP,DCQ
