Constant display.close right unit main cover in it 2870
  • aakash@24
    • May 2011
    • 41
    I have a big problem with an 2270 go, I get the message constantly RIGHT SIDE DOOR CLOSE RAND I changed the door switch, I changed the Power Supply, the Dc controller and all plates have the machine, I measured at j309 conector that reach the 24v and go, luckily have another well for testing, but the result is the same, the message remains
    It is a very rare breakdown, please apply for help
    • 8144
    Re: Constant display.close right unit main cover in it 2870
    Wow is this the same issue from 2010 !!!!????
    http://www.copytechnet.com/forums/ca...or-ir2270.html
    • aakash@24
      • May 2011
      • 41
      yeah facing same problem.
      Changed all boards and supplies but keep getting same issue.
      Any suggestions.
      Machine first showed e00227 then after replacing main power supply it got resolved and I got this code.
      I have interchanged all the boards with another one and they are all fine .
