how to solve open the toner replacement cover canon ir 3570
  • margono
    • Aug 2017
    • 14
    [CQ] how to solve open the toner replacement cover canon ir 3570
    How to solve the open the toner replacement cover message ir 3570, please help. Because I am new with this type
  • rudysemira
    • Oct 2016
    • 108
    Re: how to solve open the toner replacement cover canon ir 3570
    [ATTACH=CONFIG]37385[/ATTACH]
    Did you checked the toner lock/unlock lever if there is a broken? try to cover the photo interrupter if working or not....... if not try to check and clean.....
    • Brian8506
      • 1658
      Did you replace the toner cartridge?
      • Canuck
        Tech Specialist
        • 1713
        Possibly toner in the photointerrupt for the door...its blocked by the toner so it thinks door is closed. Pop the front cover off(screw under toner door and one on top under rubber plug at left corner near finisher). Slide cover to left to remove. Should be able to see sensor now
        • jainarayan
          What can I do for error
          open the toner replacement cover , I am stucked for this error
          please help
