Canon iR3245 - Printing problem
  • luis1984bol
    • Nov 2011
    • 155
    [Misc] Canon iR3245 - Printing problem
    Hello my friends.
    Have you ever has this problem(attached example)?20170826180914.pdf
    It happens when the customer sends to print. Looks lika a laser problem. I had change the laser unit, clean registration roller and clean all PCB.
    Do you have idea about this?. Thanks.
    Re: Canon iR3245 - Printing problem
    Originally posted by luis1984bol
    Hello my friends.
    Have you ever has this problem(attached example)?[ATTACH]37424[/ATTACH]
    not sure what you mean by " clean all PCB. "
    it looks like something could be blocking the image going to the drum.. or improper drum rotation..
    not a registration roller issue... was there a double paper feed situation?
    • techwurk
      • 127
      Looks like a paper size issue
      When I started servicing copiers they used toaster ovens for fusers.....I'm old
      • teckat
        • 16083
        Hello my friends.
        have u tested internal test prints
        • luis1984bol
          • Nov 2011
          • 155
          • luis1984bol
            • Nov 2011
            • 155
            The PCB were dusty and no double paper feed. Any ideas?
              no he is not talking about prints from the computer.. he is referring to the internal prints from the machine
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5015
                This is not driver issue. Inspect laser shutter and parts around.(cable,spring...)
                • anderson
                  • May 2009
                  • 19
                  the problem may be in the paper size sensor, or in the paper size setting in the paper tray, try changing the tray to another, or replace the printouts with tray 2 and check that the problem persists
                  • luis1984bol
                    • Nov 2011
                    • 155
                    [QUOTE=anderson;575878]the problem may be in the paper size sensor, or in the paper size setting in the paper tray, try changing the tray to another, or replace the printouts with tray 2 and check that the problem persists[/QUOTE
                    Thanks for your answers. We solve the problem replacing the Main Controller PCB.
                    • zoraldinho
                      • Mar 2008
                      • 5015
                      At the end most expensive
                      • teckat
                        • 16083
                        [QUOTE=luis1984bol;575895]
                        congrats---
                        I always double check all connections on pcb's before replacing (remove and re_seat at least twice ) some are a pain in the butt (amount), sometimes u get lucky and save a few bucks.
