Removing the Control Panel on a canon ir 2880
  • CWright
    • Sep 2012
    • 8
    Hi Copytechnet,
    Does anyone have instructions or a service manual for the ir2880, I am trying to replace the control panel. I have found the two screws on the right hand side fixing the control panel to the printer but I still cant remove it. Looking at the replacement control panel there shouldnt be any other screws holding the unit. I would rather not apply force and risk damaging the printer.
    Your help is much appreciated.
    C.Wright
  • Burdy500
    • May 2016
    • 44
    Re: Removing the Control Panel on a canon ir 2880
    Originally posted by CWright
    Hi Copytechnet,
    C.Wright
    when the screws are removed you can move it to the right and remove cables first remove right front cover
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      irc3380_2880-panel.pdf.pdf
      • NorthW
        • Jul 2017
        • 55
        Hidden screw on lefthand side of control panel, hidden behind a rubber grommet. I know from experience!
