Help!! iR C3080 Machine
  • copier tech
    • 8192
    #16
    Re: Help!! iR C3080 Machine
    If you have a doner machine swap the complete scanner unit!?
    • q555
      • May 2015
      • 81
      #17
      i will try this one definitely.
      And i will try this assembly to other machines also.
      i will update as soon as possible.
      • petermays
        • Mar 2017
        • 91
        #18
        hi..has this been sorted yet?there should be a closed button so if problem has been sorted we all know..if it hasn't and looking at all whats been done then it could be a processing problem.pcb in main pcb.pls let me know if prob has been sorted
        thank you
        • jitenderrawat1
          • Sep 2017
          • 5
          #19
          Originally posted by q555
          PG Test 10 is working perfectly fine.
          But both Glass and Feeder Scan is not, there is a straight light output.
          Anyone have encountered this kind of problem in iR C3080 machines?
          Thanks in Advance!!!
          Clean the ccd sliding rod and oil in it then move 2 or 3 times. Try copying it best of luck
          Sent from my CPH1701 using Tapatalk
