Quick question
  • Swellpix
    • Aug 2017
    • 5
    [Misc] Quick question
    Would it be bad for my printer to print over the top of another print? I'm using a canon ifp6300. Just curious[emoji15]
  • 1stcavvet
    • Apr 2015
    • 231
    Re: Quick question
    could make the finished product a little fuzzy GOOD LUCK
      • 22927
      Re: Quick question
      I don't see where it would do any harm to the machine. Is it a porous media? I hope you're not trying to register the image with another. =^..^=
      • ZOOTECH
        Senior member of CRS
        • 3374
        Re: Quick question
        Some machines can do an 'overlay' - but I've never see it work to the customer's satisfaction.
        • Swellpix
          • Aug 2017
          • 5
          Re: Quick question
          Just curious. I have several of my own prints, mostly on metallic paper of one brand or another, that for one reason or another just weren't right... Just thought I'd experiment instead of tossing them. I might stumble across something that looks really cool.
          Thanks!
          [emoji106]
          • SAZ911
            • Mar 2013
            • 193
            Re: Quick question
            Originally posted by terramobil
            If you use the same modell it will be no problem. If you use a different modell or manufacturer it can cause heavy fuser problems.
            Hi,
            Yes i have found the same thing, if you used the same printer it should be fine if you print on different devices you will get fusing issues, as the toner may have slightly different heating values, it may re melt your previous image and mess up your fuser....
            SAZ911..........
              • 22927
              Re: Quick question
              Originally posted by SAZ911
              Hi,
              No fuser in an iPF6300. It's ink based. =^..^=
              • SAZ911
                • Mar 2013
                • 193
                Re: Quick question
                hahaha,
                sorry i have copier tech eyes, i only see photocopiers,,....sorry...
                SAZ911..........
