about cloning hard disk of canon IR..
  • buboy2222
    • Aug 2017
    • 13
    Hello;
    When cloning hard disk; have you change the jumper of source hard disk to another pin? or just remain? I'm using acronis.
    Thank you.
  • cs.dk
    • Apr 2017
    • 24
    Re: about cloning hard disk of canon IR..
    That depends if they are on the same cable or not.
    • buboy2222
      • Aug 2017
      • 13
      i'm using USB 2.0 to sata IDE cable.
      • stefkpl
        • Sep 2017
        • 25
        Hi,
        with this, you don't have to touch jumpers.
        Regards
        • anderson
          • May 2009
          • 19
          what are the settings of acronis for the perfect cloning of hds?
          • stefkpl
            • Sep 2017
            • 25
            I use https://www.miray.de/download/hdclone.html not free version, Standard Edition .
            You can use default configuration with no change partions sizes.
            • spectraindo
              • May 2008
              • 313
              Hi guys, can you clone iRA6275 hard disks ?
              I have tried several programs with no results.
              • copier tech
                • 8176
                Yes, you can clone ANY Canon HDD.
                I use Acronis True Image.
                • apoxi
                  • Nov 2015
                  • 45
                  But how, the ADV62xx have encrypted disc?
