Colors are off front to rear. It may need drums but I've tried all the adjustments knowledgebase recommended. Img reg clr, color mismatch adj and auto gradation. Changed itb assembly. Had this problem on another machine and the adjustments worked. Anybody seeing drums causing this? TIA
IRA C2030 color registration
Re: IRA C2030 color registration
Hi Brian!
I really want to see a sample.preferably PG-6If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
I had something simular on a 2020 after cleaning the laserunit. But the reg. was more of on the back that the front. Reseating the laser didn't help.
Had to do several Reg-Clr and powerdown in between Color adjustments, suddenly it just was fine...JohanComment
