Canon ir-3530
  • PEPELEMU
    Tech
    • Oct 2008
    • 38
    Canon ir-3530
    Machine is jamming right before the registration roller using all trays even mp tray. Replaced feed rollers and right lower door ass'y. The paper just stops, clean lead edge no rips or nicks. Checked reg. roller springs and grounds ok. Cleaned all rollers on right side.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    And the jam code is?.....
    Because it's a new machine I'd give the rego flag spring an extra wind.
    • PEPELEMU
      Tech
      • Oct 2008
      • 38
      CANON IR-3530
      The error code is e007 which I looked up was fuser film not working properly. Does that sound like the solution. The jam was before the reg. roller it did not hit the reg actuator.
      • Jonesy
        Yeah if you have e007 then remove and check the fuser to see if you can turn it. Could be something possibly jammed in it
