Canon ir 105 is having black background on the front side of paper....
  • rudysemira
    • Oct 2016
    • 108
    Did anyone encountered this problem both copy and print in the same place..... i will be thanked in advance to all of you..
    See attached file ........... by the way the roller cylinder and drum i used to clean it but the same problem also the wires but i never tried to change the drum blade....any suggestion!
    • 8144
    Re: Canon ir 105 is having black background on the front side of paper....
    Are you using genuine toner?
    Whats the main counter on?
    What is the counter of the dev unit?
