AdvC5035 duplex on a MAC
  • repeatcopiers
    • Sep 2008
    • 591
    We installed an Adv C5035 copier today for a customer that has all Windows Operation System units except for 1 Mac running Mountain Lion OS 10.8.4. We have it printing but there is no selection for 2-sided prints available. I have absolutely no knowledge of Mac computers, can someone tell me what I am doing wrong. All the other computers (with Windows OS) in the office are working just fine.
    Second issue is setting up Scan on the MAC, is there something special I need to do, if I select FTP it won't browse to find the MAC. I only know how to set up the windows computers to scan.
    Any help is appreciated.
  • apollo
    • Mar 2008
    • 182
    Re: AdvC5035 duplex on a MAC
    Hi
    to to get more option on printer you need to open a document to print than you should get more options
    on printer and should be under finishing options for double sided .
    hope it helps
    • repeatcopiers
      • Sep 2008
      • 591
      Originally posted by apollo
      Hi
      hope it helps
      Unfortunately 2-sided still isn't listed as an option. They have an older irc3480 that is still connected to this Mac and it shows 2-sided just like the Windows computers but for some reason it isn't an option on this AdvC5035 for the Mac.
      • tech28
        • Jun 2013
        • 434
        Just a suggestion, load the full driver from Canon, you will see everything the machine has on board, the generic driver does not show everything, print quality adjustments, the lower pedestal, and they will tend to duplex every print. Good Luck. p.s. Lost a sell a few years ago because of Mac computer, the business had 4 different stations with Windows, the owner and his son had Mac's, seemed over every weekend(two) the Mac's could not see the 2 lower drawers, just the two upper, they needed to see 11/17, only the Mac didn't see it, Windows no problem, had a top IT company come out to trouble shoot, 750.00 later, still same problem, had to pull machine out. Just the way it goes sometimes.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          I had the same issue with an iR C3200 (about 15 years ago) with a Fiery.
          Same issue....no lower trays for the Macs; the PCs were OK.
          I copied the Windows PPD (PostScript Printer Definition) to a Mac, then used that PPD. (A PPD is a text file, and therefore not platform specific.)
          The lower trays (and all options, for that matter) worked OK.
          Of course, that is assuming you are using PostScript. I’ve been out of Canons for a while, but last I remember there was a Canon UFR driver for the Mac.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5013
            Same issue long time ago.If i remember i solve with ufr driver settings: device settings>get device status>apply
            After that i got duplex.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              • dan7777
                • Dec 2012
                • 680
                Yes I think this is how you do this. We had a C250 with the same issue. If this way does not work google CUPS and they will tell you what to do. Another tech who knows macs went out and did it for the customer. I rarely see Macs but yesterday had two!
