ir5055 half light
  • repeatcopiers
    • Sep 2008
    • 591
    ir5055 half light
    Canon ir5055 has intermittent light copies down half of the page. This happens on prints and copies. Very intermittent, tech made about 200 copies without an issue, then 2 pages came out like this. We have replaced all the primary corona assemblies and the HVT pcb. Any ideas?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: ir5055 half light
    What about developer?
    • dan7777
      • Dec 2012
      • 680
      Luckily I only have one or two of those left and rarely see them. When I first looked at it looked like something on laser glass but if it is intermittent maybe something like drum ground? could be charge, laser, or drum ground. I am not sure what the contacts on the back of the drum do.
        what is the life count on the drum and developer ?
        • repeatcopiers
          • Sep 2008
          • 591
          800,000
            800,000
            and the expected life is what 600,000? sounds a little high...
            • repeatcopiers
              • Sep 2008
              • 591
              Service Manual says 1,000,000 on developer but it sounds like the developer is a good idea to try next.
              • repeatcopiers
                • Sep 2008
                • 591
                Developer didn't fix it so we will try the drum tomorrow.
                • cdtw9803
                  • Aug 2009
                  • 51
                  Obviously,it's a transfer problem. Replace the wires of pre-trasfer assy. and transfer assy..(or,replace these two assys.) Then get into service mode , COPIER > OPTION > BODY>TR_SP_C1(C2,C3,C4,MF,DK) ,set these items to 2.
                  • Canuck
                    Tech Specialist
                    • 1713
                    Possibly HVT connector for transfer/sep corona assembly. They crack and leak. Its the one that the contacts on the rear of the trans/sep assembly make contact with when you close drawer and latch handle to lift the assembly. Look in the Alarms in service mode for clues...
