Black on IR C5030
  • teckat
    • 16083
    #16
    Re: Black on IR C5030
    Originally posted by maximilian500
    the drums can not be exchanged. they are not mechanically compatible. I'm just wondering that the result on heavy paper is perfectly fine. Is there a way to re-evaluate the developer? this is also just 3000 pages old.
    Have you interchanged/swapped laser scanner assemblies between black andcyan for testing ?????
    FM4-8354-010 DEVELOPING ASSEMBLY, BLACK
    See if the
    developer
    bias tab for black is pushed in and stuck in the housing > not allowing it to make proper contact.
    • maximilian500
      • Aug 2016
      • 67
      #17
      I'm not currently at the machine to change the laser units.
      • maximilian500
        • Aug 2016
        • 67
        #18
        Can it be the Primary Transfer Roller for Black ?
        • petermays
          • Mar 2017
          • 91
          #19
          the drums can not be exchanged. they are not mechanically compatible. I'm just wondering that the ris differentsult on heavy paper is perfectly fine. Is there a way to re-evaluate the developer? this is also just 3000 pages old.
          You a typical asshole arnt you.yes.you can take the drum out of the bk unit and put in a colour unit for testing.yes.voltages between bk and colour are differwnt but to test you can.i see you dont test units.ppl like you are a irritation.
          Yes..go get a new bk unit and go put in....aaaaa...its not the unit..now I have a open drum unit...or ill just leave it in machine.
          • maximilian500
            • Aug 2016
            • 67
            #20
            I tested the following Units:
            -Black Drum (with a used one from another machine)
            -secondary Transfer Roller
            -BIAS contacts
            -Laser Unit
            I basically advise my customers honestly do not sell them anything they need.
            • JPiek
              • Oct 2014
              • 435
              #21
              I thought we treated each other with respect overhere... No need to call someone names...
              Johan
