ImagePress C1+II - Need Help with Fuser Connector to body wiring
  • mattyc
    • 5
    Canon ImagePress C1+ II
    I'm looking for the correct part numbers for the connectors that connect the fuser to the body of the machine.
    I need both parts (male & female). One of the plastic ears on the connector that is attached to the body of the machine cracked off, resulting in the connector pushing through on one side. Ultimately, this resulted in the other connector (attached to the fuser) being damaged when the drawer was closed (pins bent and mangled).
    I have the back of the machine open and removed the broken part. Can anyone tell me the correct part numbers that I need. The only thing marked on the body side piece is M808.
    Thanks for any help you can provide on this.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: ImagePress C1+II - Need Help with Fuser Connector to body wiring
    Fm2-2620-000 1 fixing heater cable unit
    fm2-2627-000 1 ac driver cable ass'y
