LBP 7750 cdn, code E078-0001
  • masky
    • Aug 2010
    • 56
    [Error Code] LBP 7750 cdn, code E078-0001
    I have this printer with the code e078-0001, someone can help me, I do not have the technical manual,
    if someone can indicate where to get it ... thank you very much
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5019
    Re: LBP 7750 cdn, code E078-0001
    Error Codes > Canon > i-SENSYS LBP7750Cdn > Code E078-0001
    • masky
      • Aug 2010
      • 56
      some part list in case I need to order the spare part????
      thanks
      • Oscar M
        • Apr 2013
        • 5
        You should change the fixing drive unit (ref: RM1-4974-000)
        • vallvejo
          • Aug 2011
          • 10
          hola,debe actualizar el equipo a una version nueva de firmware.Y asi se soluciona.
          • airsoftsnake
            • Jan 2024
            • 17
            Do you have the latest firmware for this printer?
            • airsoftsnake
              • Jan 2024
              • 17
              Just wanted to update this thread to state that updating to the latest firmware made the issue go away, as suggested above (7.10).
              Thanks to "wav" who was able to help me with this.
              • jaro74
                • Mar 2024
                • 10
                Hi, were you able to locate the firmware? can you please let me know where to find it?
                • airsoftsnake
                  • Jan 2024
                  • 17
                  Yes, please become a contributor.
                  Also, which firmware are you currently running?
                  • MOLICN
                    • Mar 2024
                    • 26
                    Attention!!
                    A skilled technician is needed for disassembly and assembly. Ordinary personnel should pay attention to disassembly and assembly, as the drive clutch is located inside the drive gear.
                    After removing the cover on the right side of the machine from the front, you can see a drive clutch. The softening of the clutch release sponge caused the machine to have inaccurate calibration between the drive drum and the ITB component color block sensor, resulting in malfunction.
                    The method is very simple: remove the clutch, remove the softened sponge, replace it with a layer of electrical tape and install it to solve the problem.
                    • jaro74
                      • Mar 2024
                      • 10
                      Could you tell me how to check the version of the firmware?
                      Looking through the menu options on the printer I can't seem to find it.
                      • Oscar M
                        • Apr 2013
                        • 5
                        If you print the configuaration page, at the top left you will see the version
                        • Oscar M
                          • Apr 2013
                          • 5
                          • jaro74
                            • Mar 2024
                            • 10
                            The situation is the printer won't print, it goes directly into the E078-0001 error. For that reason it won't let me check the IP number either.
                            Is there anywhere to see the IP when I can't print the configuration page?
                            I have it connected to a MacBook and there's no printer IP showing anywhere.
                            • airsoftsnake
                              • Jan 2024
                              • 17
                              You can force the IP address of the printer on the printer...
                              settings / std network menu / TCP/IP settings / IP v4 settings / ip address settings / IP address
                              It should show you the current one... (and you can modify it)...
                              Then, you connect to that page (IP address)... my admin password was nothing, just "enter", and then you can get the info...
