Canon IR 3300 Control Panel Repair
  • adel_nathan
    • Jul 2011
    • 103
    [Misc] Canon IR 3300 Control Panel Repair
    Hi every body
    i have canon IR3300 , it's working good , but there are some important switch doesn't work ,( like * and 2,8)
    so i disassembly it and try to fix , but it doesn't work
    please , i ask for help , how can i fix it ?
    thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon IR 3300 Control Panel Repair
    If you can use 2 or 8 button for copy job and not for the service mode then the panel is not broken!
    Try *49*
    Check if any key has been stuck.
    • adel_nathan
      • Jul 2011
      • 103
      some switches not response whatever copy or service mode
      no one stuck
      it's need to clean, adjust and fix
      please , i need to know how can i fix them ?
      • zoraldinho
        • Mar 2008
        • 5015
        It's hard to repair. Buy used one.
        Used & Original Control Panel For Canon Printers Ir3300,For Canon Printer Spare Parts - Buy For Canon Printers,For Canon Printer Spare Parts,Control Panel Lcd For Canon Printers Ir3300 Product on Alibaba.com
        • dan7777
          • Dec 2012
          • 680
          Originally posted by adel_nathan
          Hi every body
          thanks
          You can take the buttons off and put on ones from a used panel, I have done that. If you make copies the 2 and 8 keys don't work? The other posts say to put in a used board. Those machines are really old and parts are harder to get.
          • anderson
            • May 2009
            • 19
            remove the adhesive tape from the key contacts and polish the metal parts, the circuit you can clean with clean contact spray, then put another tape to the same size that was removed
            any doubt send me an email
            aejpereira28@yahoo.com.br
