c6010 color displacement
  • mc921
    • Oct 2015
    • 23
    After restarting the yellow starter, i am experiencing a radical color displacement. i executed at-img-x, auto img with no change. also tried LD adj for each color. also reseated connectors from dc controller to laser sub driver pcb. any thoughts??
    thx
  • mc921
    • Oct 2015
    • 23
    Re: c6010 color displacement
    here is the fix: i found this on an earlier thread from khattab.al.masry. worked perfectly!!
    1-init-itb
    2-itb-edge
    3-intr-ex
    4-at-img-x
    5-auto-img
    if this sequences failed you will have trail and error to bring color to acceptable level.
    print pg6 and see how much off black you evaluate this by holding the lead edge of PG 6 towards your left side, if black is towards the left side of other colors , then go to copier>adj>laser>LNSMTR K and make +300, and do ATIMGX. After this do the routine Copier>Function>laser>LDAJD K . Continue this till the Black is within the range and then ATMGX will be able to bring back colors.
