Paper Jam in IR3300
  • princepriyu
    • Aug 2025
    Paper Jam in IR3300
    Hi Friends
    I'm having a problem with Canon IR3300
    paper jams at the same location
    right side door
    the roller doesn't rotates constantly
    NO ERROR CODES
    Please can anyone guide to the solution
    • 23009
    Re: Paper Jam in IR3300
    How about jam codes? Is the paper lifting properly? Any "clackety clack" noises? =^..^=
    • princepriyu
      thanks for reply
      no error codes, just paper stops there, no noise even
      i'v also tried another tray. it also stops at the same location,
      paper pickup is perfect, i'v installed with new set of rubbers
      i have noticed if i use bypass it works fine with single sided,
      but it gets jammed at the same location if i use back to back
      • jper34
        • Sep 2011
        • 225
        it's been awhile,
        but I think there are sub rollers(white), that are meshing with the gray ones..there was a quick kit to fix that issue, without having to replace the whole unit. But check to see if the sub rollers are making contact with the gray ones..
        • IndoCE
          • Nov 2014
          • 14
          Originally posted by princepriyu
          Hi Friends
          right side door
          Refer Image [ATTACH=CONFIG]38091[/ATTACH]
          NO ERROR CODES
          I think you must cek JAM code , not error code
            • 23009
            Yes Jam Codes. We need jam codes to help you. =^..^=
            • princepriyu
              here's the JAM CODE list
              thank you very much
              I Really appreciate your help
              • Hopper2
                • Aug 2017
                • 14
                [ATTACH=CONFIG]38098[/ATTACH]
                thank you very much
                The 0105 and 0103 is run of th mill paper feed issues. 0105 says it tried to pick up once, 05 is a second attempt at a pick up.
                THE 008* in the third column is VODOO. Boot your copier up and see if it has defaulted to the manual feed tray. Hit reset three times and it will set back to the paper trays/auto paper select and try to feed from there. If it is booting up asking for paper size from manual feed tray there is a little black arm missing. Open the manual feed tray and on the out side of the paper path and on the side of the door a black 1' long part goes on a lever that gets involved with the mp roller.
                • Hopper2
                  • Aug 2017
                  • 14
                  Also:
                  You are in Europe trying to print on A4 paper, not LTR
                  Disconnect trys 3 and 4 paper feed unit. I have seen it cause start up stationary 0201 jams.
                  • princepriyu
                    Finally the machine started printing . . . .
                    Solution :-
                    i had to remove the cable harness from the board behind the machine
                    and remove the dust from it, reconnect it. it started working
                    lifting the paper without JAM.
                    But,
                    works for some time may be 150-200 pages print &
                    again starts the JAM
                    again i have to clean the connectors, then the machine starts
                    what must be the problem i checked the connectivity of the cables the are fine !!
