canon ir advance c5045i
  • NEOTECH
    • Dec 2010
    • 69
    [Misc] canon ir advance c5045i
    hi dear i perches used irc5045i copier machine when i make copy machine display massage remove paper from output try my machine is no finisher installed without finisher basic copier
    how can i solved this problem.
    any one help me.
    thanks
  • adi1986
    • Nov 2017
    • 1
    Re: canon ir advance c5045i
    any one help me.
    thanks
    Did this machine came with external fiinishing unit?
    • roho
      • Mar 2009
      • 844
      A sensor arm has been removed, likely this had a finisher at one point. You need to take a flashlight and look at the back of the paper delivery area, you will see a small area to your right that likely has a small cover removed and you will likely see a sensor there. You may simply block it, should feed paper then.
      • Drcopy
        • Jan 2017
        • 57
        Roho is on the money, block that sensor and it should be fine.
        • lilleputte
          • Jan 2013
          • 154
          If you have Buffer Pass Unit-G1 installed but no finisher.
          1. COPIER > OPTION > ACC
          2. IN-TRAY to "1"
          3. Paper output settings
          Output Tray Designation - Canon imageRUNNER ADVANCE C5255/C5250/C5240/C5240A/C5235A e-Manual
