Canon ir adv8085 slow
  • mramlawi
    • Jul 2011
    • 838
    Wonder that 8085 pro advance machine mu costmer told me its too slow the 6055 is more faster than it in print and copy, im using finisher D1 ,i updated the machine and still saw it slow i also changed the finisher with another one.
    any one face this before
    Distinguished road makes you jewel in rough
  • Herrmann
    • Jan 2006
    • 792
    Re: Canon ir adv8085 slow
    Did you monitor the fusing temp? if it gets too low, the mashine slows down, maybe this is a hint in the right direction
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • charm5496
      • 2387
      paper stock settings on plain, and not something funky?
      is it starting out at rated speed and then slowing down?
      • mramlawi
        • Jul 2011
        • 838
        Honestly i replaced the fuser and still the same also i changed the hard disk and still same, i changed the finisher also . The machine slow on 2 sided both on copy and print.
        • aco.bk
          • Sep 2012
          • 130
          with or without imagePASS-U1 (Optional)???
            duplexing always slows down the output speed.
            so can improper paper type... check the paper setting thru control panel and thru the driver...
            • Herrmann
              • Jan 2006
              • 792
              Just a shot in the dark:
              I had a similar problem on a advc7065, it turns out to be the image controller (main controller 2 if i remember correctly)
              If you have an organ donor, maybe you can give it a try
              • mramlawi
                • Jul 2011
                • 838
                without U1 Fiery also on copy 2 sided slow
                • mramlawi
                  • Jul 2011
                  • 838
                  Yes i moniterd the heater also i changed it and changed the hard disk and still same problem
                  • mramlawi
                    • Jul 2011
                    • 838
                    Stocked paper is normal
