IPF755 lines in yellow only
  • digicor
    • Jul 2008
    • 1159
    I have the lines in this example, the nozzle check comes out good, is there a cleaning utility20171220100903478.pdf i can use, i cant seem to locate anything in the maint section20171220101454976_0002.jpg20171220101454976_0001.jpg
    thanks for any help
    Re: IPF755 lines in yellow only
    Originally posted by digicor
    I have the lines in this example, the nozzle check comes out good, is there a cleaning utility[ATTACH]38450[/ATTACH] i can use, i cant seem to locate anything in the maint section[ATTACH=CONFIG]38451[/ATTACH][ATTACH=CONFIG]38452[/ATTACH]
    thanks for any help
    that could be just to the Speed/quality you are printing it in .. try high quality see if you still get the banding
    • digicor
      • Jul 2008
      • 1159
      Solved! I used a water pick type device with a small cleaning head that resembled a small brush, used 2 parts 70 alch, and 8 parts regular windex,(from youtube) cleaned the print head itself, twice, then switched to the water "pick" style tip and ran it through the ink ports, all of this on the lowest setting of coarse ,dried it carefully, re installed, ran the head cleaning, A and B , and presto all lines gone ,pics are magnificent!
      saved myself 300-400 dollars, just be very careful not to get ANY solution on the circuit side of the print head, its not to hard to do.
