Ir 3300 e350-3000 and e350-00002
  • pearlpdy
    • Jul 2008
    • 44
    [Error Code] Ir 3300 e350-3000 and e350-00002
    Dear all technicians i have problem in machine ir3300. error occured e350-3000 and in service mode in clear all ram clear then again error show e350-0002, i have replace another counter board and counter serial board, but no way to solutin pls help me
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Ir 3300 e350-3000 and e350-00002
    Do you want help for cheat someone?
    • Brian8506
      • 1664
      And that is why you have that code. It doesn't pay to cheat
      • teckat
        • 16083
        Counter PCBs and SATA Flash PCBs are no longer available for purchase.
        As a result, please handle E350 / E355 and E748 in the following manner:
        E350 / E355 Error Codes:
        Call the Technical Support Center (1-800-528-2830)
        *NOTE 1: For any of these error codes, do not swap any PCB's from any other machine. Doing so may render both machines unrecoverable.
        *NOTE 2: Do not use any of the User Mode or Service Mode clears when encountering these error codes. Executing the Service Mode or User Mode clears may render the machine unrecoverable.
        • copier tech
          • 8144
          Put ALL the original boards back in the machine.
          Go to service mode level 2 & perform E355 clear.
          If this fails your machine is scrap.
          • santhosh088
            • Jan 2018
            • 1
            mfc board
